the only difference is the Gpio for SF1.
in some it is the Gpio14 in others the Gpio4
Gniazdko Neo Coolcam z pomiarem energii
@elmaya
Me gustaría:
LED Blue ( gpio2 ) - config
LED Red ( gpio0 ) - Relay on/off
Mis cambios - // new
¿Qué más debo hacer?
LED Blue ( gpio2 ) - config - Funciona
LED Red ( gpio0 ) - Relay on/off - No funciona
Me gustaría:
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
#include "LittleFS.h" // LittleFS is declared
#include <SuplaDevice.h>
#include <supla/sensor/one_phase_electricity_meter.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- V6 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <Ticker.h> //for LED status
#include <ESP8266TrueRandom.h>
#include <HLW8012.h>
extern "C"
#include "user_interface.h"
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
#define SEL_PIN 12
#define CF1_PIN 4 // 14 new
#define CF_PIN 5
#define status_led 2 // 0 new
#define status_led_red 0 // _red new
int wificonfig_pin = 13;
int relay_pin = 15;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 5000; // config delay 5 seconds new
int C_W_state2 = HIGH;
long C_W_delay2 = 100;
unsigned long eep_milis = 10000;
bool recover = true;
char Supla_server[81]=("Set server address");
char Email[81]=("set email address");
char Supla_name[51];
char Supla_status[51];
char Volt[8];
char Wats[8];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
int s = 0;
bool starting = true;
bool Tik = true;
unsigned long mem_energy_milis = 3000000;
float mem_energy = 0;
float _mem_energy = 0;
int customFieldLength = 40;
WiFiManagerParameter custom_field; // global param ( for non blocking w params )
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16]; // UUIDs in binary form are 16 bytes long
static const char custom_radio_str[] PROGMEM = "<br><div style='text-align:center; width:100%; padding:0;'><label for='customfieldid'>Counter mem</label><input type='radio' name='customfieldid' value='0' checked>keep Storage<input type='radio' name='customfieldid' value='1'>clear Storage</div>";
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
Ticker ticker;
Supla::ESPWifi wifi("", ""); //------ Do not change----wifimanager takes care------
Supla::Control::Relay *relay1 = nullptr;
#define CURRENT_MODE LOW
#define HJL01_CURRENT_RATIO 25740
#define HJL01_VOLTAGE_RATIO 313400
#define HJL01_POWER_RATIO 3414290
HLW8012 hjl01;
class Hj101 : public Supla::Sensor::OnePhaseElectricityMeter {
public:
Hj101() {
void onInit() {
readValuesFromDevice();
updateChannelValues();
virtual void readValuesFromDevice() {
unsigned int _reactive = 0;
double _pf = 0;
double _current = hjl01.getCurrent();
unsigned int _voltage = hjl01.getVoltage();
unsigned int _active = hjl01.getActivePower();
unsigned int _apparent = _voltage * _current;
if (_apparent > _active) {_reactive = sqrt(_apparent * _apparent - _active * _active); } else {_reactive = 0;}
if (_active > _apparent){ _pf = 1;} if (_apparent == 0){ _pf = 0;}else{ _pf = (double) _active / _apparent;}
// voltage in 0.01 V
setVoltage(0,_voltage * 100);
// current in 0.001 A
setCurrent(0, _current * 1000);
// power in 0.00001 kW
setPowerActive(0, _active * 100000);
// energy in 0.00001 kWh
setFwdActEnergy(0, ((float)hjl01.getEnergy() + mem_energy) / 6 / 6 );
// power in 0.00001 kVA
setPowerApparent(0, _apparent * 100000);
// power in 0.00001 kvar
setPowerReactive(0, _reactive * 100000);
// power in 0.001
setPowerFactor(0, _pf * 1000);
void tick() {
int state = digitalRead(status_led);
digitalWrite(status_led, !state);
void ICACHE_RAM_ATTR hjl01_cf1_interrupt() {
hjl01.cf1_interrupt();
void ICACHE_RAM_ATTR hjl01_cf_interrupt() {
hjl01.cf_interrupt();
void calibrate_hj101() {
int ex_volt = atoi(Volt);
int ex_pow = atoi(Wats);
double ex_amps = ((float)ex_pow / (float)ex_volt);
Serial.print("volt:"); Serial.println(ex_volt);
Serial.print("wats:"); Serial.println(ex_pow);
Serial.print("amps:"); Serial.println(ex_amps);
digitalWrite(relay_pin,HIGH);
Serial.println("Relay On:");
unsigned long timeout1 = millis();
while ((millis() - timeout1) < 10000) { delay(10);}
hjl01.expectedActivePower(ex_pow);
hjl01.expectedVoltage(ex_volt);
hjl01.expectedCurrent(ex_amps);
unsigned long timeout2 = millis();
while ((millis() - timeout2) < 2000) {delay(10);}
double current_multi = hjl01.getCurrentMultiplier();
double voltage_multi = hjl01.getVoltageMultiplier();
double power_multi = hjl01.getPowerMultiplier();
Serial.print("[HLW] New current multiplier : "); Serial.println(current_multi);
Serial.print("[HLW] New voltage multiplier : "); Serial.println(voltage_multi);
Serial.print("[HLW] New power multiplier : "); Serial.println(power_multi);
EEPROM.put(400, current_multi);
EEPROM.put(410, voltage_multi);
EEPROM.put(420, power_multi);
EEPROM.write(430, 60);
EEPROM.commit();
yield();
void get_hj101_config(){
if (EEPROM.read(430) == 60){
Serial.println("get eep multiplier ");
double p_m;double v_m;double c_m;
EEPROM.get(400,c_m);
EEPROM.get(410,v_m);
EEPROM.get(420,p_m);
hjl01.setCurrentMultiplier(c_m);
hjl01.setVoltageMultiplier(v_m);
hjl01.setPowerMultiplier(p_m);
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void ondemandwifiCallback () {
// ticker.attach(1.5, tick); // old
ticker.attach(0.2, tick); // new
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required");
WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required");
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManagerParameter custom_Supla_status("status", "Supla Last State", Supla_status, 51,"readonly");
WiFiManagerParameter custom_Volt("Volt", "expectedVoltage", Volt, 8);
WiFiManagerParameter custom_Wats("Wats", "expectedActivePower", Wats, 8);
new (&custom_field) WiFiManagerParameter(custom_radio_str); // custom html input
wifiManager.setBreakAfterConfig(true);
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.setSaveParamsCallback(saveParamCallback);
wifiManager.addParameter(&custom_Supla_server);
wifiManager.addParameter(&custom_Email);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_Supla_status);
wifiManager.addParameter(&custom_Volt);
wifiManager.addParameter(&custom_Wats);
wifiManager.addParameter(&custom_field);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality(8);
//wifiManager.setShowStaticFields(true); // force show static ip fields
//wifiManager.setShowDnsFields(true); // force show dns field always
wifiManager.setConfigPortalTimeout(180);
if (!wifiManager.startConfigPortal("Gosund_SP111")) { Serial.println("Not connected to WiFi but continuing anyway.");} else { Serial.println("connected...yeey :)");}
strcpy(Supla_server, custom_Supla_server.getValue());
strcpy(Email, custom_Email.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
strcpy(Volt, custom_Volt.getValue());
strcpy(Wats, custom_Wats.getValue());
if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){
Serial.println("new guid & authkey.");
EEPROM.write(300, 0);
EEPROM.commit();
ESP.reset();
if ((strlen(Volt) != 0) && (strlen(Wats) != 0)){
calibrate_hj101();
WiFi.softAPdisconnect(true); // close AP
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
if (s != status){
s = status;
if (s != 10){
strcpy(Supla_status, msg);
Serial.print("Status: ");Serial.print(s);Serial.print(" ");Serial.println(Supla_status);
String getParam(String name){
String value;
if(wifiManager.server->hasArg(name)) {
value = wifiManager.server->arg(name);
if (value == "1"){
float cler = 0.0;
EEPROM.put(460, cler);
EEPROM.commit();
Serial.println("clearStorage");
return value;
void saveParamCallback(){
Serial.println("[CALLBACK] saveParamCallback fired");
Serial.println("PARAM customfieldid = " + getParam("customfieldid"));
void Eeprom_save(){
if (digitalRead(relay_pin)!= EEPROM.read(431)){
_mem_energy = (double)hjl01.getEnergy() + mem_energy;
EEPROM.put(460, _mem_energy);
EEPROM.write(431,digitalRead(relay_pin));
EEPROM.commit();
Serial.println("mem relay + energy");
void guid_authkey(void) {
if (EEPROM.read(300) != 60){
int eep_gui = 301;
ESP8266TrueRandom.uuid(uuidNumber);
String uuidString = "";
for (int i = 0; i < 16; i++) {
int topDigit = uuidNumber[i] >> 4;
int bottomDigit = uuidNumber[i] & 0x0f;
uuidString += "0123456789abcdef"[topDigit];
uuidString += "0123456789abcdef"[bottomDigit];
int length_uuid = uuidString.length();
for (int i = 0; i < length_uuid; ++i) {
EEPROM.put(eep_gui + i, uuidString[i]);
int eep_aut = 341;
String uuidString2 = "";
uuidString2 += "0123456789abcdef"[topDigit];
uuidString2 += "0123456789abcdef"[bottomDigit];
int length_uuid2 = uuidString2.length();
for (int i = 0; i < length_uuid2; ++i) {
EEPROM.put(eep_aut + i, uuidString2[i]);
float cler = 0.0;
EEPROM.write(300, 60);
EEPROM.commit();
read_guid();
read_authkey();
Serial.print("GUID : ");Serial.println(read_guid());
Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
String read_eeprom = "";
int i, ii = 0;
int eep_star = 301;
int end_guid = eep_star + SUPLA_GUID_SIZE;
String temp_read = "0x";
for (i = eep_star; i < end_guid + 16; i = i + 1) {
temp_read += char(EEPROM.read(i));
read_eeprom += char(EEPROM.read(i));
if ( (i % 2) == 0) {
char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
GUID[ii] = strtoul( _guid, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
String read_authkey(void) {
int i, ii = 0;
int eep_star = 341;
int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
for (i = eep_star; i < end_authkey + 16; i = i + 1) {
char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
temp_read = "0x";
ii++;
return read_eeprom;
void setup() {
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200);
Serial.println();
EEPROM.begin(1024);
pinMode(wificonfig_pin, INPUT_PULLUP);
pinMode(status_led,OUTPUT);
digitalWrite(relay_pin, EEPROM.read(431));
guid_authkey();
ticker.attach(0.8, tick); // new 0.5
if (WiFi.SSID()==""){ initialConfig = true;}
if (LittleFS.begin()) { // ------------------------- wificonfig read -----------------
Serial.println("mounted file system");
if (LittleFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = LittleFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonDocument json(1024);
DeserializationError deserializeError = deserializeJson(json, buf.get());
serializeJsonPretty(json, Serial);
if (!deserializeError) {Serial.println("\nparsed json");
if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
if (json.containsKey("Email")) strcpy(Email, json["Email"]);
if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
} else {
Serial.println("failed to load json config");
configFile.close();
} else {
Serial.println("failed to mount FS");
wifi_station_set_hostname(Supla_name);
hjl01.setCurrentMultiplier(HJL01_CURRENT_RATIO);
hjl01.setVoltageMultiplier(HJL01_VOLTAGE_RATIO);
hjl01.setPowerMultiplier(HJL01_POWER_RATIO);
// void begin(unsigned char cf_pin, unsigned char cf1_pin, unsigned char sel_pin, unsigned char currentWhen = HIGH, bool use_interrupts = false, unsigned long pulse_timeout = PULSE_TIMEOUT);
hjl01.begin(CF_PIN, CF1_PIN, SEL_PIN, CURRENT_MODE, true);
get_hj101_config();
attachInterrupt(CF1_PIN, hjl01_cf1_interrupt, FALLING);
attachInterrupt(CF_PIN, hjl01_cf_interrupt, FALLING);
EEPROM.get(460, mem_energy);
_mem_energy = mem_energy;
Serial.print("mem energy: ");
Serial.println(mem_energy);
relay1 = new Supla::Control::Relay(relay_pin);
new Hj101();
SuplaDevice.setName(Supla_name);
SuplaDevice.setStatusFuncImpl(&status_func);
wifi.enableSSL(false);
SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY);
char buffer[50];
void loop() {
if (initialConfig == true){ondemandwifiCallback();EEPROM.write(431, 0); EEPROM.commit();}
int C_W_read = digitalRead(wificonfig_pin);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay2) {
if (C_W_read != C_W_state2) {
C_W_state2 = C_W_read;
if (C_W_state2 == LOW) {
Serial.println("short press");
if (!relay1->isOn()) {
relay1->turnOn();
yield();
Serial.println("relayOn");
Eeprom_save() ;
}else{
relay1->turnOff();
yield();
Serial.println("relayOff");
Eeprom_save() ;
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("long press");
C_W_state = C_W_read;
if (C_W_state == LOW) {
ondemandwifiCallback () ;
last_C_W_state = C_W_read;
if (shouldSaveConfig == true) { // ------------------------ wificonfig save --------------
Serial.println(" config...");
json["Supla_server"] = Supla_server;
json["Email"] = Email;
json["Supla_name"] = Supla_name;
File configFile = LittleFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
serializeJson(json, configFile);
configFile.close();
Serial.println("Config written successfully");
WiFi.mode(WIFI_STA);
delay(5000);
ESP.restart();
if (s == 17){
if ((Tik == true) && (WiFi.status() == WL_CONNECTED)){ticker.detach();Tik = false;}
if(millis() > eep_milis){
Eeprom_save() ;
eep_milis = millis() + 3000 ;
if (recover){
Serial.println("ticker off");
if (EEPROM.read(431) == true){
relay1->turnOn();
yield();
recover = false;
if ((s != 17) && (Tik == false)) { ticker.attach(0.8, tick);Tik = true;Serial.println("ticker on no 17"); } // new 0.5
//if ((WiFi.status() != WL_CONNECTED) && (Tik == false)){ticker.attach(0.5, tick);Tik = true;Serial.println("ticker on no wifi"); }
if (s == 10){recover = true;}
SuplaDevice.iterate();
delay(50);
if (WiFi.status() == WL_CONNECTED){
if (starting){
httpUpdater.setup(&httpServer, "/update", "admin", "pass");
httpServer.begin();
starting = false;
httpServer.handleClient();
if ((digitalRead(relay_pin) == digitalRead(status_led)) && (s ==17)){
digitalWrite(status_led,!digitalRead(relay_pin));
if(millis() > mem_energy_milis){
if ((float(hjl01.getEnergy()) + mem_energy > _mem_energy) && (digitalRead(relay_pin) == HIGH)){
Serial.println("save energy");
_mem_energy = (float)hjl01.getEnergy() + mem_energy;
EEPROM.commit();
mem_energy_milis = millis() + 600000 ;
Nie jest to ładny kawałek kodu ale wstaw to w loop()
void turnOnRedLed() {
if ((digitalRead(relay_pin) == HIGH) && (digitalRead(red_led_pin) == HIGH)) {
digitalWrite(red_led_pin, LOW);
if ((digitalRead(relay_pin) == LOW) && (digitalRead(red_led_pin) == LOW)) {
digitalWrite(red_led_pin, HIGH);
To co dodałem ma komentarz z moim nickiem.
#include <EEPROM.h>
extern "C"
//#define D1 5
//#define D2 4
//#define D5 14
//#define D6 12
//#define D7 13
#define SEL_PIN 12
#define CF_PIN 5
int relay_pin = 15;
char Volt[8];
char Wats[8];
byte mac[6];
int s = 0;
bool Tik = true;
Ticker ticker;
HLW8012 hjl01;
public:
Hj101() {
void onInit() {
double _pf = 0;
// power in 0.001
void tick() {
void turnOnRedLed() { // lukfud
if ((digitalRead(relay_pin) == HIGH) && (digitalRead(status_led_red) == HIGH)) {
digitalWrite(status_led_red, LOW);
if ((digitalRead(relay_pin) == LOW) && (digitalRead(status_led_red) == LOW)) {
digitalWrite(status_led_red, HIGH);
EEPROM.commit();
yield();
EEPROM.commit();
ESP.reset();
calibrate_hj101();
if (s != status){
s = status;
if (s != 10){
String value;
if (value == "1"){
float cler = 0.0;
EEPROM.commit();
return value;
void Eeprom_save(){
EEPROM.commit();
int eep_gui = 301;
int eep_aut = 341;
float cler = 0.0;
EEPROM.commit();
read_guid();
read_authkey();
int i, ii = 0;
int eep_star = 301;
temp_read = "0x";
ii++;
return read_eeprom;
int i, ii = 0;
int eep_star = 341;
temp_read = "0x";
ii++;
return read_eeprom;
void setup() {
Serial.println();
EEPROM.begin(1024);
pinMode(status_led_red,OUTPUT); // lukfud
digitalWrite(status_led_red,HIGH); // lukfud
guid_authkey();
if (configFile) {
} else {
configFile.close();
} else {
get_hj101_config();
new Hj101();
char buffer[50];
void loop() {
turnOnRedLed(); // lukfud
relay1->turnOn();
yield();
Eeprom_save() ;
}else{
relay1->turnOff();
yield();
Eeprom_save() ;
if (!configFile) {
configFile.close();
delay(5000);
ESP.restart();
if (s == 17){
Eeprom_save() ;
if (recover){
relay1->turnOn();
yield();
recover = false;
delay(50);
if (starting){
httpServer.begin();
starting = false;
EEPROM.commit();
Zakomentuj tego if'a i sprawdź
Witajcie,elmaya pisze: ↑pn lis 23, 2020 10:01 pmthat model has CF1 connected to Gpio4 and not to Gpio14Maniek913 pisze: ↑pn lis 23, 2020 8:17 pm
Thanks a lot for your work
I put this soft into a similar socket -BliTZWOIF BW-SPH6 15A 3450W. Everything works, it measures energy, but apart from power in "W" and consumption in "kWh", it does not show other parameters in the application - voltage, current, etc.
This is correct? however, are these sockets different?
try with this
BlizWolf_BW-SHP6_15A_LittleFS_DOUT_8Mbit.rar
Tak informacyjnie.
Gniazdko GOSUND SP111.
Wgrałem przez tuja-converter Updater GUI Generic.
Następnie Soft elmaya dla SHP6 15A
Wszystko działa, bez rozbierania.
Zalecam wgrywanie softów z OTA, wtedy można żeby zmienić soft wystarczy wgrać ponownie updatera i później kolejny soft.
/Budek
update for Gosund _SP111_v_1.1_15A
With the collaboration of @Patryk, the software has been optimized for this model, also adding the second Led to show the status of the relays.
#include <supla/io.h>
#include <EEPROM.h>
extern "C"
//#define D1 5
//#define D2 4
//#define D5 14
//#define D6 12
//#define D7 13
#define SEL_PIN 12
#define CF1_PIN 4
#define CF_PIN 5
#define wificonfig_pin 13
#define relay_pin 15
char Volt[8];
char Wats[8];
byte mac[6];
int s = 0;
bool Tik = true;
unsigned long mem_energy_milis = 300000;
Ticker ticker;
HLW8012 hjl01;
class CustomControl : public Supla::Io {
public:
void customDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
if (pin == relay_pin){ // if the call is for relay_pin
::digitalWrite(relay_pin,val); // set value to relay_pin
::digitalWrite(status_led_red,!val); // set value to status_led_red
}else{
return ::digitalWrite(pin,val); // just in case there were more channels
}CustomControl;
public:
Hj101() {
void onInit() {
double _pf = 0;
// power in 0.001
void tick() {
digitalWrite(status_led_red,!HIGH);
Serial.print("[HLW] Active Power (W) : "); Serial.println(hjl01.getActivePower());
Serial.print("[HLW] Voltage (V) : "); Serial.println(hjl01.getVoltage());
Serial.print("[HLW] Current (A) : "); Serial.println(hjl01.getCurrent());
EEPROM.commit();
yield();
EEPROM.commit();
ESP.reset();
calibrate_hj101();
if (s != status){
s = status;
if (s != 10){
String value;
if (value == "1"){
float cler = 0.0;
EEPROM.commit();
return value;
void Eeprom_save(){
EEPROM.commit();
int eep_gui = 301;
int eep_aut = 341;
float cler = 0.0;
EEPROM.commit();
read_guid();
read_authkey();
int i, ii = 0;
int eep_star = 301;
temp_read = "0x";
ii++;
return read_eeprom;
int i, ii = 0;
int eep_star = 341;
temp_read = "0x";
ii++;
return read_eeprom;
void setup() {
Serial.println();
EEPROM.begin(1024);
digitalWrite(status_led_red, !EEPROM.read(431));
guid_authkey();
if (configFile) {
} else {
configFile.close();
} else {
get_hj101_config();
new Hj101();
char buffer[50];
void loop() {
relay1->turnOn();
yield();
Eeprom_save() ;
}else{
relay1->turnOff();
yield();
Eeprom_save() ;
if (!configFile) {Serial.println("failed to open config file for writing");}
configFile.close();
delay(5000);
ESP.restart();
if (s == 17){
if ((Tik == true) && (WiFi.status() == WL_CONNECTED)){ticker.detach();digitalWrite(status_led, LOW);Tik = false;}
Eeprom_save() ;
if (recover){
relay1->turnOn();
yield();
recover = false;
//if ((WiFi.status() != WL_CONNECTED) && (Tik == false)){ticker.attach(0.8, tick);Tik = true;Serial.println("ticker on no wifi"); }
delay(50);
if (starting){
httpServer.begin();
starting = false;
EEPROM.commit();
