About own supla server
Post Reply
psp50
Thank have install supla on own ubantu server. And it is working fine for me.
Can anybody help to find the path of the web files?
I want to modify website interface but I don’t know where can i find that files.
Kindly help.
Contact:
Have you used a docker?
psp50
pzygmunt wrote: Fri Oct 29, 2021 7:39 am Have you used a docker?
Yes
I'm using docker.
this method.
https://github.com/SUPLA/supla-docker
Contact:
The cloud sources are here
https://github.com/SUPLA/supla-cloud
Information on where they are kept in the container can be found here.
https://github.com/SUPLA/supla-docker/b ... Dockerfile
psp50
pzygmunt wrote: Fri Oct 29, 2021 10:14 am The cloud sources are here
Thank you so much for your responce.
I understand but I am unable to find files that are in supla-cloud.
where supla-cloud files are located.
this is the file list on my server.
Screenshot 2021-10-29 180924.png (53.55 KiB) Viewed 1371 times
I have also searched supla-cloud files like config.php etc using the command line but I did not get files with that names.
Kindly help me with it.
Contact:
/var/www/cloud
Post Reply
Return to “Help”
