Good idea but everything is correct. To be sure, I entered the same thing again.
Sonoff logs in under the network service and I can check the parameters, connection status etc.
Unfortunately, we do not log in to the server, I checked with a second location on the server and the same.
Maybe sonoff is broken?
I checked the board in two modules and nothing.
Do you have sonof-basic soft? I'll check if it works.
I have over 20 devices that are sent and supported by the server. The fact is that your soft works much better on touch than on other available.
hej potrzebuje pomocy z uruchomieniem trybu flashowania.
do you use compiled soft "Bin" or do you compile it with Arduino Ide?
when you check "supla last State" can you see the data you entered before "supla server, user id, userpass, Etc"?
you can try the server ip instead of svrxx.supla.org
hello.
I program with flasher nodemcu. Everything always worked ok, I saved the settings as you would on your screen. It is interesting that only your soft is loading properly. Other software won't start after saving - weird? Today I will try to program with the flasher you recommend.
Can I have the software link again?
thanks.
thanks.
you are probably using the wrong flash size, 8Mbit = 1MByte with flasher nodemcu you have to select 1MByte
ESP8266 Download Tool
https://www.espressif.com/sites/default ... v3.6.8.zip
I got up wonderfully I have it in the app
A great beer for you, thanks to one call again, is there an option to set the wifi diode all the time in the on state - that is, the diode is lit up with a constant blue light when sonoff is logged in and functional.
Cześć.
Mam jeszcze pytanie do softu dlaczego app. w telefonie widzi dwa termometry ?
Jeden właściwy a drugi -127.
Czy jest jakaś opcja aby wyłaczyć jeden z termometrów ?
Jeżeli wyłącze termometr w aplikacji web znikają obydwa.
Hey.
I still have a question for software why the app. can he see two thermometers in the phone?
One correct and the other -127.
Is there any option to turn off one of the thermometers?
If I turn off the thermometer, both will disappear in the web application.
Hey.
