IOT SDK
Czy ktoś (z forum) potrafił by dodać:
supla_esp_input_set_hold_time_ms(CZAS_W_MS);
supla_esp_input_set_multiclick_time_ms(INNY_CZAS_W_MS);
do konfiguracji (html):
static char html_template[] =
      "%s%s<div class=\"s\"><svg version=\"1.1\" id=\"l\" x=\"0\" y=\"0\" "
      "viewBox=\"0 0 200 200\" xml:space=\"preserve\"><path "
      "d=\"M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,"
      "3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,"
      "23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5."
      "4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4."
      "5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-"
      "10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,"
      "5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2."
      "8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6."
      "3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-"
      "10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4."
      "2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z "
      "M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,"
      "35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0."
      "4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5."
      "6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-"
      "14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-"
      "4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z "
      "M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18."
      "6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79."
      "2,67.1,89,55.9,89,42.6z "
      "M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5."
      "9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,"
      "102.1,188.6z "
      "M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11."
      "4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88."
      "5z\"/></svg><h1>%s</h1><span>LAST STATE: %s<br>Firmware: %s<br>GUID: "
      "%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X<br>MAC:"
      " %02X:%02X:%02X:%02X:%02X:%02X</span><form id=\"cfgform\" "
      " method=\"post\"><div "
      "class=\"w\"><h3>Wi-Fi Settings</h3><i><input name=\"sid\" "
      "value=\"%s\"><label>Network name</label></i><i><input "
      "name=\"wpw\"><label>Password</label></i></div><div "
      "class=\"w\"><h3>Supla Settings</h3><i><input name=\"svr\" "
      "value=\"%s\"><label>Server</label></i><i><input name=\"eml\" "
      "value=\"%s\"><label>E-mail</label></i></div><div "
      "class=\"w\"><h3>Additional Settings</h3><i><select name=\"led\"><option "
      "value=\"0\" %s>LED "
      "ON<option value=\"1\" %s>LED OFF</select><label>Status - "
      "LED</label></i></div><button "
      "type=\"submit\">SAVE</button><br><br>"
      "<button type=\"button\" onclick=\"saveAndReboot();\">SAVE &amp; "
      "RESTART</button>"
      "<input type=\"hidden\" name=\"rbt\" value=\"0\" />"
      "</form></div><br><br>";
  int bufflen = strlen(supla_esp_get_laststate()) + strlen(dev_name) +
                strlen(SUPLA_ESP_SOFTVER) + strlen(supla_esp_cfg.WIFI_SSID) +
                strlen(supla_esp_cfg.Server) + strlen(supla_esp_cfg.Email) +
                strlen(html_template_header) + strlen(html_template) + 200;
  char *buffer = (char *)malloc(bufflen);
  ets_snprintf(
      buffer, bufflen, html_template, html_template_header,
      data_saved == 1 ? "<div id=\"msg\" class=\"c\">Data saved</div>" : "",
      dev_name, supla_esp_get_laststate(), SUPLA_ESP_SOFTVER,
      (unsigned char)supla_esp_cfg.GUID[0],
      (unsigned char)supla_esp_cfg.GUID[1],
      (unsigned char)supla_esp_cfg.GUID[2],
      (unsigned char)supla_esp_cfg.GUID[3],
      (unsigned char)supla_esp_cfg.GUID[4],
      (unsigned char)supla_esp_cfg.GUID[5],
      (unsigned char)supla_esp_cfg.GUID[6],
      (unsigned char)supla_esp_cfg.GUID[7],
      (unsigned char)supla_esp_cfg.GUID[8],
      (unsigned char)supla_esp_cfg.GUID[9],
      (unsigned char)supla_esp_cfg.GUID[10],
      (unsigned char)supla_esp_cfg.GUID[11],
      (unsigned char)supla_esp_cfg.GUID[12],
      (unsigned char)supla_esp_cfg.GUID[13],
      (unsigned char)supla_esp_cfg.GUID[14],
      (unsigned char)supla_esp_cfg.GUID[15], (unsigned char)mac[0],
      (unsigned char)mac[1], (unsigned char)mac[2], (unsigned char)mac[3],
      (unsigned char)mac[4], (unsigned char)mac[5], supla_esp_cfg.WIFI_SSID,
      supla_esp_cfg.Server, supla_esp_cfg.Email,
      supla_esp_cfg.StatusLedOff == 0 ? "selected" : "",
      supla_esp_cfg.StatusLedOff == 1 ? "selected" : "");
  return buffer;
void ICACHE_FLASH_ATTR supla_esp_board_gpio_init(void) {
	supla_input_cfg[0].type = INPUT_TYPE_BTN_MONOSTABLE;
	supla_input_cfg[0].gpio_id = B_CFG_PORT;
	supla_input_cfg[0].flags = INPUT_FLAG_PULLUP | INPUT_FLAG_CFG_BTN | INPUT_FLAG_TRIGGER_ON_PRESS;
	supla_input_cfg[0].relay_gpio_id = B_RELAY1_PORT;
	supla_input_cfg[0].channel = 1;
        supla_esp_input_set_hold_time_ms(300);
        supla_esp_input_set_multiclick_time_ms(500);
Za dobrą kawę ?
kris.sg
@Patryk tu masz na szybko zrobione:
plytka h:
#ifndef P_SONOFF_BASIC_H_
#define P_SONOFF_BASIC_H_
#define ESP8285 // nowy
#define ESP8266_SUPLA_PROTO_VERSION 16 // 12
#define RETREIVE_CHANNEL_CONFIG 0b10 // AT
#define LED_RED_PORT    13
// #define AP_SSID "S_Basic" // nowy, ale wtedy nie dziala kreator dodawania z apki
#define BOARD_ON_CONNECT  // LED CFG zgaszona przy normalnej pracy
#define BOARD_CFG_HTML_TEMPLATE // nowy config z LED ON/OFF
#define CFG_TIME_VARIABLES
// #define INPUT_MIN_CYCLE_COUNT 6 // nowy czas
// #define INPUT_CYCLE_TIME 21 // nowy czas
char *ICACHE_FLASH_ATTR supla_esp_board_cfg_html_template(
char dev_name[25], const char mac[6], const char data_saved); // nowy config z LED ON/OFF
void ICACHE_FLASH_ATTR supla_esp_board_on_connect(void); //LED CFG zgaszona podczas normalnej pracy
void ICACHE_FLASH_ATTR supla_esp_board_send_channel_values_with_delay(void *srpc);
#endif
plytka c:
const uint8_t rsa_public_key_bytes[512] = {
#define B_RELAY1_PORT    12
#define B_CFG_PORT        0
void ICACHE_FLASH_ATTR supla_esp_board_set_device_name(char *buffer, uint8 buffer_size) {
		ets_snprintf(buffer, buffer_size, "S_Basic_T_AT v1.1");
    char dev_name[25], const char mac[6], const char data_saved) {
  static char html_template_header[] =
      "<!DOCTYPE html><meta http-equiv=\"content-type\" content=\"text/html; "
      "charset=UTF-8\"><meta name=\"viewport\" "
      "content=\"width=device-width,initial-scale=1,maximum-scale=1,user-"
      "scalable=no\"><style>body{font-size:14px;font-family:HelveticaNeue,"
      "\"Helvetica Neue\",HelveticaNeueRoman,HelveticaNeue-Roman,\"Helvetica "
      "Neue "
      "Roman\",TeXGyreHerosRegular,Helvetica,Tahoma,Geneva,Arial,sans-serif;"
      "font-weight:400;font-stretch:normal;background:#00d151;color:#fff;line-"
      "height:20px;padding:0}.s{width:460px;margin:0 auto;margin-top:calc(50vh "
      "- 340px);border:solid 3px #fff;padding:0 10px "
      "10px;border-radius:3px}#l{display:block;max-width:150px;height:155px;"
      "margin:-80px auto 20px;background:#00d151;padding-right:5px}#l "
      "path{fill:#000}.w{margin:3px 0 16px;padding:5px "
      "0;border-radius:3px;background:#fff;box-shadow:0 1px 3px "
      "rgba(0,0,0,.3)}h1,h3{margin:10px "
      "8px;font-family:HelveticaNeueLight,HelveticaNeue-Light,\"Helvetica Neue "
      "Light\",HelveticaNeue,\"Helvetica "
      "Neue\",TeXGyreHerosRegular,Helvetica,Tahoma,Geneva,Arial,sans-serif;"
      "font-weight:300;font-stretch:normal;color:#000;font-size:23px}h1{margin-"
      "bottom:14px;color:#fff}span{display:block;margin:10px 7px "
      "14px}i{display:block;font-style:normal;position:relative;border-bottom:"
      "solid 1px "
      "#00d151;height:42px}i:last-child{border:none}label{position:absolute;"
      "display:inline-block;top:0;left:8px;color:#00d151;line-height:41px;"
      "pointer-events:none}input,select{width:calc(100% - "
      "145px);border:none;font-size:16px;line-height:40px;border-radius:0;"
      "letter-spacing:-.5px;background:#fff;color:#000;padding-left:144px;-"
      "webkit-appearance:none;-moz-appearance:none;appearance:none;outline:0!"
      "important;height:40px}select{padding:0;float:right;margin:1px 3px 1px "
      "2px}button{width:100%;border:0;background:#000;padding:5px "
      "10px;font-size:16px;line-height:40px;color:#fff;border-radius:3px;box-"
      "shadow:0 1px 3px "
      "rgba(0,0,0,.3);cursor:pointer}.c{background:#ffe836;position:fixed;"
      "width:100%;line-height:80px;color:#000;top:0;left:0;box-shadow:0 1px "
      "3px rgba(0,0,0,.3);text-align:center;font-size:26px;z-index:100}@media "
      "all and (max-height:920px){.s{margin-top:80px}}@media all and "
      "(max-width:900px){.s{width:calc(100% - "
      "20px);margin-top:40px;border:none;padding:0 "
      "8px;border-radius:0}#l{max-width:80px;height:auto;margin:10px auto "
      "20px}h1,h3{font-size:19px}i{border:none;height:auto}label{display:block;"
      "margin:4px 0 "
      "12px;color:#00d151;font-size:13px;position:relative;line-height:18px}"
      "input,select{width:calc(100% - "
      "10px);font-size:16px;line-height:28px;padding:0 5px;border-bottom:solid "
      "1px #00d151}select{width:100%;float:none;margin:0}}</style><script "
      "type=\"text/javascript\">"
      "function saveAndReboot(){"
      "var e=document.getElementById(\"cfgform\");"
      "e.rbt.value=\"2\",e.submit()"
      "setTimeout(function(){var element =  "
      "document.getElementById('msg');if ( element != null ) "
      "element.style.visibility = \"hidden\";},3200);"
      "</script>";
      "102.1,188.6z "
      "class=\"w\"><h3>Additional Settings</h3><i><input name=\"t10\" "
      "type=\"number\" value=\"%i\"><label>HOLD TIME (700ms) "
      "</label></i><i><input name=\"t11\" type=\"number\" "
      "value=\"%i\"><label>MULTICLICK TIME (300ms) </label></i>"
	  "<i><select name=\"led\"><option "
    //  "connected</label></i><i><select name=\"upd\"><option value=\"0\" "
   //   "%s>NO<option value=\"1\" %s>YES</select><label>Firmware "
      "RESTART</button>"
  ets_snprintf(
	  supla_esp_cfg.Time1[0] > 0 ? supla_esp_cfg.Time1[0] : 700,
      supla_esp_cfg.Time1[1] > 0 ? supla_esp_cfg.Time1[1] : 300,
  return buffer;
	supla_input_cfg[0].channel = 1; // ???
// if (supla_esp_cfg.CfgButtonType == BTN_TYPE_MONOSTABLE) {
    supla_input_cfg[0].action_trigger_cap =
      SUPLA_ACTION_CAP_HOLD |
      SUPLA_ACTION_CAP_SHORT_PRESS_x1 |
      SUPLA_ACTION_CAP_SHORT_PRESS_x2 |
      SUPLA_ACTION_CAP_SHORT_PRESS_x3 |
      SUPLA_ACTION_CAP_SHORT_PRESS_x4 |
      SUPLA_ACTION_CAP_SHORT_PRESS_x5;
 // } else {
 //   supla_input_cfg[0].type = INPUT_TYPE_BTN_BISTABLE;
 //   supla_input_cfg[0].action_trigger_cap =
 //     SUPLA_ACTION_CAP_TURN_ON   |
 //     SUPLA_ACTION_CAP_TURN_OFF  |
 //     SUPLA_ACTION_CAP_TOGGLE_x1 |
 //     SUPLA_ACTION_CAP_TOGGLE_x2 |
 //     SUPLA_ACTION_CAP_TOGGLE_x3 |
 //     SUPLA_ACTION_CAP_TOGGLE_x4 |
 //     SUPLA_ACTION_CAP_TOGGLE_x5;
    supla_relay_cfg[0].gpio_id = B_RELAY1_PORT;
    supla_relay_cfg[0].flags = RELAY_FLAG_RESTORE_FORCE;
    supla_relay_cfg[0].channel = 0;
void ICACHE_FLASH_ATTR supla_esp_board_set_channels(TDS_SuplaDeviceChannel_C *channels, unsigned char *channel_count) {
	*channel_count = 2;
	channels[0].Number = 0;
	channels[0].Type = SUPLA_CHANNELTYPE_RELAY;
	channels[0].FuncList = SUPLA_BIT_FUNC_POWERSWITCH \
								| SUPLA_BIT_FUNC_LIGHTSWITCH;
	channels[0].Default = SUPLA_CHANNELFNC_POWERSWITCH;
        channels[0].Flags |= SUPLA_CHANNEL_FLAG_COUNTDOWN_TIMER_SUPPORTED; // Nowy Timer
	channels[0].Flags |= SUPLA_CHANNEL_FLAG_CHANNELSTATE; // Nowy poziom wifi itd...
        channels[0].value[0] = supla_esp_gpio_relay_on(B_RELAY1_PORT);
channels[1].Number = 1;
  channels[1].Type = SUPLA_CHANNELTYPE_ACTIONTRIGGER;
  channels[1].FuncList = SUPLA_CHANNELFNC_ACTIONTRIGGER;
  channels[1].Default = SUPLA_CHANNELFNC_ACTIONTRIGGER;
  channels[1].ActionTriggerCaps = supla_input_cfg[0].action_trigger_cap;
  channels[1].Flags = SUPLA_CHANNEL_FLAG_CHANNELSTATE;
  channels[1].actionTriggerProperties.relatedChannelNumber = 1;
  channels[1].actionTriggerProperties.disablesLocalOperation =
   // SUPLA_ACTION_CAP_TOGGLE_x1 | SUPLA_ACTION_CAP_SHORT_PRESS_x1;
  SUPLA_ACTION_CAP_SHORT_PRESS_x1; // tylko monostabilny
void ICACHE_FLASH_ATTR supla_esp_board_send_channel_values_with_delay(void *srpc) {
	supla_esp_channel_value_changed(0, supla_esp_gpio_relay_on(B_RELAY1_PORT));
void ICACHE_FLASH_ATTR supla_esp_board_on_connect(void) {     // LED CFG zgaszona podczas normalnej pracy
  supla_esp_gpio_set_led(supla_esp_cfg.StatusLedOff, 0, 0);   // LED CFG zgaszona podczas normalnej pracy
	supla_log(LOG_DEBUG, "Set hold time = %i", supla_esp_cfg.Time1[0]);
	supla_log(LOG_DEBUG, "Set multiclick time = %i", supla_esp_cfg.Time1[1]);
	supla_esp_input_set_hold_time_ms(supla_esp_cfg.Time1[0]);
	supla_esp_input_set_multiclick_time_ms(supla_esp_cfg.Time1[1]);
Sprawdziłem u siebie i jest ok :)
POW_R2 x2 ■SP111 x3
Nawet nie wiesz, jak się cieszę. :D :D :D
Czy inne ustawienie tych czasów:
https://github.com/SUPLA/supla-espressi ... #L154-L160
ma jakiś wpływ na te czasy :
https://github.com/SUPLA/supla-espressi ... #L673-L681
Czy jest to niezależne ? :?:
Patryk pisze: pn mar 21, 2022 11:35 am Czy inne ustawienie tych czasów:
Z tego co pamiętam, to te INPUT_MIN.. muszą upłynąć, aby układ wykrył wciśnięcie lub zwolnienie przycisku.
Od tego momentu są mierzone czasy hold i multiclick.
Także są one zależne.
Dzięki, za info.
bicker
cześć
Robicie to już w 3.xx czy jeszce w 2.xx ??
bicker pisze: wt maja 17, 2022 9:10 am cześć
"iot sdk" z supla-espressif-sdk jest i będzie tylko dla starych wersji ESP SDK 2.x. W zasadzie to będzie on głównie w trybie "maintanance".
Wersję "Supli na urządzenia", która jest rozwijana, znajdziesz tutaj https://github.com/SUPLA/supla-device
Pierwotnie była to wersja biblioteki dla Arduino IDE, ale jest też już dostępny wariant na ESP8266 RTOS SDK (3.x) oraz ESP-IDF (dla ESP32).
bicker
klew pisze: wt maja 17, 2022 10:24 am
dzięki
Wróć do „Zagadnienia ogólne”
