Poprawiłem, błąd mojej ostatniej poprawki.Z J pisze: ↑śr lut 23, 2022 8:41 pm Hej,
ESP32 - 1 wire
tym razem mam taki błąd:Kod: Zaznacz cały
/var/www/html/code/GUI-Generic_bv4.5_gv4.6.23_pl_133d4728db18227f3a25bf04fbc16245/SuplaConfigESP.cpp: In member function 'void SuplaConfigESP::rebootESP()': /var/www/html/code/GUI-Generic_bv4.5_gv4.6.23_pl_133d4728db18227f3a25bf04fbc16245/SuplaConfigESP.cpp:149:7: error: 'class EspClass' has no member named 'reset' ESP.reset(); ^ Error during build: exit status 1 xxxxxxxxxxxxxxxxxx BOARD esp32:esp32:d32:PartitionScheme=min_spiffs BOARD_NAME TEMPLATE_BOARD TEMPLATE_JSON JSON_DEFINITION OPTIONS -DATOMIC_FS_UPDATE -DBEARSSL_SSL_BASIC -DSUPLA_CONFIG -DSUPLA_DS18B20 -DSUPLA_ENABLE_GUI -DSUPLA_OTA
Wsparcie GUI-Generic dla ESP32
Tym razem podczas generowania pliku nawet bez żadnych opcji mam błąd:
Błąd generowania
In file included from /root/.arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/WiFi/src/WiFi.h:31:0,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaConfigESP.h:40,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaDeviceGUI.h:30,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/GUIGenericCommon.cpp:18:
/var/www/html/code/lib/SuplaDevice/src/supla/network/esp_wifi.h: In member function 'virtual void Supla::ESPWifi::setup()':
/root/.arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/WiFi/src/WiFiType.h:35:22: error: 'ARDUINO_EVENT_WIFI_STA_GOT_IP' is not a member of 'system_event_id_t'
#define WiFiEvent_t system_event_id_t
/var/www/html/code/lib/SuplaDevice/src/supla/network/esp_wifi.h:181:11: note: in expansion of macro 'WiFiEvent_t'
WiFiEvent_t::ARDUINO_EVENT_WIFI_STA_GOT_IP);
/root/.arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/WiFi/src/WiFiType.h:35:22: error: 'ARDUINO_EVENT_WIFI_AP_STADISCONNECTED' is not a member of 'system_event_id_t'
/var/www/html/code/lib/SuplaDevice/src/supla/network/esp_wifi.h:188:11: note: in expansion of macro 'WiFiEvent_t'
WiFiEvent_t::ARDUINO_EVENT_WIFI_AP_STADISCONNECTED);
from /root/.arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/WebServer/src/WebServer.h:29,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaHTTPUpdateServerESP32.h:5,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaHTTPUpdateServerESP32.cpp:11:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebCorrection.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebCorrection.cpp:17:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be.ino:16:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaOled.cpp:18:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaTemplateBoard.cpp:18:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageDeviceSettings.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageDeviceSettings.cpp:17:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageHome.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageHome.cpp:17:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageConfig.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageConfig.cpp:17:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageDownload.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageDownload.cpp:17:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageControl.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageControl.cpp:17:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaDeviceGUI.cpp:16:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaConfigManager.cpp:25:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaConfigESP.cpp:16:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageLimitSwitch.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageLimitSwitch.cpp:17:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/Markup.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/Markup.cpp:17:
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageOther.h:20,
from /var/www/html/code/GUI-Generic_bv4.5_gv4.8.1_pl_7aed883486e9bab5f8dc1b2fc953f4be/SuplaWebPageOther.cpp:17:
xxxxxxxxxxxxxxxxxx
BOARD_NAME
TEMPLATE_BOARD
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DBEARSSL_SSL_BASIC -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_OTA
Dziękuję, poszło
Nie polecam tego obejścia. Poczekajcie cierpliwie az ogarniemy nasze sprawy prywatne i zrobimy aktualizacje. Miało być szybko ale nie wyszło
https://gui-generic-builder.supla.io/test.php
[/quote]
Dziękuję, poszło
[/quote]
Super .ale jest to GG 4.6.11 i nie ma poprawek do GG.4.8.4 na https://gui-generic-builder.supla.io/
Pisze żeby nie było ze coś nie działa
[/quote]
Dziękuję, poszło
[/quote]
